vcPackFolder
vcPackFolder allows you to pack files with a VCMX file and extract them. Files are contained in a folder that is mapped to a layout or component. Generally, you would map a temporary folder that you want to save with a VCMX file, and then extract the folder and its contents when you open the VCMX file. This allows you to share a layout or component that contains other files, for example a CSV file of robot position data.
Referenced by: vcComponent.PackFolder, vcLayoutPackFolder.PackFolder, vcRrsRobotController.RobotDataPackFolder
PackFolderLocalPathStringRGets the file path of mapped folder.
StatevcPackFolderStateRGets the state of mapped folder.
See: 'vcPackFolderState' for available values.
mapFolderNoneString uriMaps a temporary folder generated by the application or an existing folder at the given uri which must be a file path.
Files will be packed/extracted at the time of call.
uri (str): The local folder path or empty string.
remapFolderNoneString uriRemaps a different folder.
This will not override the other folder until you save the VCMX file.
Files in the other folder will also not be deleted unless they were contained in a temporary folder generated by the application.
uri (str): The local folder path.
ValueError: If the given path is empty.
rollbackFolderNoneNoneRemoves mapping to folder.
Generally, this is used before you map a different folder.
